Hello, I am using a ULINKPro on a MCB1700 (LPC1768) dev board. I am having an issue where when I setup and run in debug mode, the code will break where I set a break point but when I press F10 to just jump over a line or press F5 to go to the next break point, the system just hangs and dosnt hit any more break points untill I reset an run again. This is very frustrating! Anyone have this issue before? I have tried just about every setting in the debugger setup. Here are my settings:
ULINK pro Cortex Debugger Load app on startup, run to main, no init file. V1.50 firmware SWJ, Port:SW MaxClock 1MHz Connect: Normal Reset: Autodetect Reset after connect Cache Code Cache Memory Verify Code Download
Trace disabled
Flash download: Erase Full Chip, Program, Verify Start = 0x10000000 Size = 0x0800 LPC17xx IAP 512kB flash
Any ideas?
Here's what I would try: - Don't run to main and see how far you can single-step - Start with a brand new minimal app
It seems that something with the ADCs was causing issues with the debugger. I was doing a continious coversion, when I disabled this code, I was able to step instructions again. Anyone have this issue before?
