Hard fault when branching to main
I am working in a C++ project for STM3210C-Eval Board (Cortex-M3). I wrote some classes and got the project working perfectly. Then I designed other classes to increment project functionalities and the system no longer works. Debugging, I have noticed that the main function is not executed. So, I started the execution from Reset routine in startup code.
; Reset handler
Reset_Handler    PROC
                 EXPORT  Reset_Handler             [WEAK]
        IMPORT  __main
                 LDR     R0, =__main
                 BX      R0
                 ENDP
When I step into "BX R0" instruction the exception Hard Fault happens and the system hangs in an endless loop. I could see that the value loaded into R0 is 0x08000151, whereas the original value of __main is 0x08000150.
Could someone help me?
  • Hi again,
    I solved the problem. I made a mistake. One of the classes had a recursive constructor. So, whenever the code responsible for static allocation (__main function) was executed it resulted in a hard fault (maybe stack overflow).
    I hope this experience helps other developers.
  • Hi again,
