Good afternoon,
I'm trying to register a serial (com-0) interrupt using uVision 3 on the Cypress FX2LP. The code compiles fine, but the linker warns:
WARNING L16: UNCALLED SEGMENT, IGNORED OVERLAY PROCESS SEGMENT: ?PR?COM_ISR?MAIN
My ISR looks like this:
static void com_isr (void) interrupt 4 { char c; if (RI) { c = SBUF0; // read character RI = 0; // clear interrupt request flag if (istart + ILEN != iend) { inbuf[iend++ & (ILEN-1)] = c; } } if (TI != 0) { TI = 0; // clear interrupt request flag if (ostart != oend) { // if characters in buffer and SBUF0 = outbuf[ostart++ & (OLEN-1)]; // transmit character sendfull = 0; } else { // if all characters transmitted sendactive = 0; // clear 'sendactive' } } }
This code is pretty much copy and pasted from the Keil Help section on Serial Transmission.
This ISR is not being called, even with IE=0x80 (to enable global interrupts) and ES0 = 1 (to enable serial 0 interrupts). Does anyone have any suggestions?
Thanks,
Montana
If there are no other publics in the file, it will not be linked. Just put a global variable (used elsewhere) in this file, or put an initialisation routine in THIS file, of which you are sure it is been called from another place. Or just include the interrupt routine within another sourcefile.
Are you sure?
In C51, an ISR cannot be called directly - so it is never "linked".
Or, looking at it another way, the interrupt keyword tells the compiler to enter the function's address in the vector table, thus creating an "implicit" call which - which should ensure that it gets "linked" (otherwise the warning would be "unresolved external" rather than "uncalled function"...?)
