hello,I use KEIL uvision and ulink2 to test the uart of lpc2366. And the Uart0 can transmit and receive data fine; when change the code to use uart2, the uart2 only can transmit data, but lpc2366 will reset and can't receive data when host transmit data to lpc2366; I had checked the code several times. I find the lpc2366 can't go into the interrupt, but I can't deal with it. I think the code to initial UART VIC has some wrong.
The code of UART2 is as follow:
#define UART2_BAUD (9600) #define UART2_INT 28 uint8 rcv2_buf[16]; volatile uint8 rcv2_new; void __irq IRQ_UART2 (void) { uint8 i; uint32 IIR = 0; while (((IIR = U2IIR) & 0x01) == 0) { switch (IIR & 0x0e) { case 0x02: break; case 0x04: //Rx FIFO for (i=0; i<8; i++) { rcv2_buf[i] = U2RBR; } break; case 0x0c: //CTI for (i=8; i<16; i++) { rcv2_buf[i] = U2RBR; } rcv2_new=2; IO0CLR |= 0x3<<27; break; case 0x06: break; default : break; } } VICVectAddr = 0x00; } void UART2_Init(void) { uint32 Fdiv = 0; PCONP |= 1 << 24; PINSEL0 |= (0x01 << 20) | (0x01 << 22); U2LCR = 0x83; // Fdiv = (Fpclk / 16) / UART2_BAUD; // set uart2 baud U2DLM = Fdiv / 256; U2DLL = Fdiv % 256; U2LCR = 0x03; // DLAB=0 U2FCR |= 0x87; // U2FDR &= ~0x0f; // DIVADDVAL=0 U2FDR |= 0x10; // MULVAL=1 U2IER = 0x05; /* init UART VIC */ VICIntEnClr |= 1 << UART2_INT; VICVectPri8 = 0x05; VICVectAddr8 = (uint32)IRQ_UART2; VICIntEnable |= 1 << UART2_INT; }
Why do you use VICVectAddr8 if the UART2 interrupt is 28?
U2LCR = 0x83; // Fdiv = (Fpclk / 16) / UART2_BAUD; // set uart2 baud U2DLM = ( Fdiv / 256 ); U2DLL = ( Fdiv % 256;) U2LCR = 0x03; // DLAB=0
