Hi guys, Ä° have mcbstm32c kit, it has 320x240 lcd i am using keil sample projects. i need to convert bitmaps to c file.Which converter does keil use to create c header file.I found some converters but they didnt work with keil's sample projects and with them i couldnt see the right image
Hi Shamak; I couldnt find tool directory,i looked into C:\Keil... in my pc but there is not a directory named tool. where is this directory?
Thanks for your helping...
