Hello! I have a typedef union and variable:
typedef union int2char{unsigned char high_byte; unsigned char low_byte; unsigned int int_byte; } int2char; int2char dac_value;
When i assign
dac_value.int_byte = 0xAAAA;
i have
dac_value.int_byte = 0xAAAA; dac_value.low_byte = 0xAA; dac_value.high_byte = 0xAA;
but when i assign,example,0xFF05
dac_value .int_byte = 0xFF05; dac_value.low_byte =0xFF; dac_value.high_byte = 0xFF;
same results are obtained when i assign,example,0x1005
dac_value .int_byte = 0x1005; dac_value.low_byte =0x10; dac_value.high_byte = 0x10;
I can not understand where the error and why?? thanks for the help!.
