Typedef union problem
Hello! I have a typedef union and variable:
typedef union int2char{unsigned char high_byte;
                       unsigned char low_byte;
                       unsigned int  int_byte;
                      } int2char;
int2char dac_value;
When i assign
dac_value.int_byte = 0xAAAA;
i have
dac_value.low_byte = 0xAA;
dac_value.high_byte = 0xAA;
but when i assign,example,0xFF05
dac_value .int_byte = 0xFF05;
dac_value.low_byte =0xFF;
dac_value.high_byte = 0xFF;
same results are obtained when i assign,example,0x1005
dac_value .int_byte = 0x1005;
dac_value.low_byte =0x10;
dac_value.high_byte = 0x10;
I can not understand where the error and why??
thanks for the help!.
