When I start up a circuit board with LPC2468 and SD connector (SD interface in 4-bit mode). without SD card present there is no problem. When I then insert a certain SD Card (2GB, SD Standard, manufacturer : Transcend), the controller will reset and restart again. After restarting the SD Card is functioning correctly. If a use a SD Card (128MB, SD Standard) from an other manufacturer (PQI) I don't have that problem.
What could be the cause of this problem ?
Kind regards.
There is a bug in your software that causes it to crash!
You need to do some debugging: first, to find out where, exactly, it is crashing; and then you can start looking into why it is crashing!
When debugging, it is very important to pay very close attention to all details.
You have tried 2 cards that differ in both size and supplier - so you really don't know yet whether it's the size or the supplier that matters!
Debugging tips here: www.8052.com/.../120313 (not 8052 specific)
Thank you for your support. When I disable all SD Card functions, the problem still occurs. It seems to be a hardware problem.
Kind regards,
"It seems to be a hardware problem"
What makes you say that? Again, don't jump to conclusions!
... would be a) a power glitch when the SD card is inserted b) noise generated when the SD card is inserted get out the scope and find out
Although rather unlikely that this would be affected by different brands and/or sizes of card?
"get out the scope and find out"
Definitely.
Current consumption during power up can make a difference, or initial load on processor pins.
Yes, that could happen - and, I guess, a bigger card might have a higher startup peak...
As Erik said, a 'scope would show for sure...
Seems to be a power consumption problem when starting up the Card. After some hardware adjustments the problem is solved.
Thank you all for your suggestions/remarks.
And thank you for reporting-back with your conclusion.
