I'm using the Keil C51 Tools and have successfully written 8051 programs only in assembly language. Now I need add C code to my assembly program. After the i add C code to my assembly code Keil C51 has grasped a part of space DATA memory. Now i can not use DATA space for some assembly variables. My C code running in the start programm and i can sharing DATA space _DATA_GROUP_ with my assebly variables. How can i make DATA segments for sharing DATA space between _DATA_GROUP_ and my assembly variables?
Note that there is an entire section in the C51 Manual titled, "Interfacing C to Assembler"
http://www.keil.com/support/man/docs/c51/c51_ap_ctoasm.htm
You have studied it, haven't you?
Also the sections that tell you how to control C51's usage of the 8051's various memory spaces:
http://www.keil.com/support/man/docs/c51/c51_le_memareas.htm http://www.keil.com/support/man/docs/c51/c51_le_memmodels.htm etc,...
Yes, Andy. I studied it. I use C and Assembler successful in my Code. But now i have some problem. I made a C code for some task used long long integer values. I use C8051F344 chip. It has 80 DATA space. My assembler code use about 64 bytes DATA space already. When Keil compiles my assembler code with C code it gives a 60 bytes DATA space for _DATA_GROUP_ and the stayed DATA space is insufficiently for my assembler variables. I used XDATA space for all C variables. I use stdlib.lib, stdio.lib and string.lib in my C code. After the compiling C code a size of _DATA_GROUP_ has 42 bytes but it is insufficiently for my assembler code. I could not reduce the size of _DATA_GROUP. Now i ask how can i use the same of DATA space as _DATA_GROUP_ because i know the C code will work at the start my program and then will work assembler code only. Or second way how can i make that C code use XDATA space only. Thank, Andy.
look at "OVERLAYABLE"
I Use for my XPOWYMODN.C i assebler code: myDATA_DATA SEGMENT DATA OVERLABLE; ?XD?XPOWYMODN_MAIN SEGMENT XDATA
in C code i use XDATA for my C variables. Memory map of linker are: DATA 0028H 002AH UNIT _DATA_GROUP_ DATA 0052H 0020H UNIT MYSTACK
and error *** ERROR L107: ADDRESS SPACE OVERFLOW SPACE: DATA SEGMENT: MYDATA_DATA LENGTH: 001FH How can i force the linker to place MYDATA_DATA in address 0028H with length 001FH without error L107?
Some correcting:
myDATA_BIT SEGMENT BIT; myDATA_DATA SEGMENT DATA OVERLAYABLE; mySTACK SEGMENT DATA; myDATA_IDATA SEGMENT IDATA; myData_XDATA SEGMENT XDATA;
and error
*** ERROR L107: ADDRESS SPACE OVERFLOW SPACE: DATA SEGMENT: MYDATA_ DATA LENGTH: 001FH
