Here is my problem, i have several simmilar structue definitions (containers for messages)
struct FIRST{ unsigned char Word_Pos[8] unsigned char Data[8] unsigned char Msg_Len }; struct FIRST A
struct SECOND{ unsigned char Word_Pos[4] unsigned char Data[4] unsigned char Msg_Len }; struct SECOND B
struct THIRD{ unsigned char Word_Pos[10] unsigned char Data[10] unsigned char Msg_Len }; struct THIRD C
Is there a way to declare single pointer (lets say "P") such that i will be able to point to each of these structures so i can transparently use: P->Word_Pos [] P->Data [] P->MSG_Len in my ISR.
I realise i could just declare 3 structures of type THIRD and just use one pointer easily, but in my actual application there will be many of these simmilar but different structures and i am trying to save ram.
How about a union?
...might it not be better to be agnostic to the message type, simply working with putting raw bytes to/from a buffer - and leave the message packing/unpacking to the main application...?
You are absolutely right. I will most likely create a union of type unsigned char[] and my structure.
BTW not that it makes much difference but Data was supposed to be an unsigned int not char. I wish it was as easy as a sequential buffer read though. When transmitted each word needs to be byte swapped. There can be up to 100 two byte words however we will never modifying more than 8 words in any message. All unmodified words need a 0x00 transmitted as a placeholder
I guess now the uses of Word_Pos becoms more apparent...
