USBMem on Chip-Driver issue
I run the USBMem USB on-chip driver as one of the example from LPC13xx that run on KEIL, when it is run and downloaded on the LPCXpresso Baseboard mounted with LPC1343 board it did'n work properly. During debugging, it appears a new USB disk drive (Removable Disk F:) but when I double click the removable disk drive a message window will pop up "You need to format the disk in drive F: before you can use it".....Does anyone know how to resolve this issue? Please help...
Thanks a lot.
