LP23XX Correct Write Embbeded Flash Sequence
As I did not manage to write to 512 Ko Flash using FL-Flash. I coded routines from the LPC23XX manual that make use of IAP commands.
I use the CCLK wired to 12MHz XTAL : CCLK is 48000 kHz.
I coded the following sequence to write to a sector :
prepare
erase
prepare
write
return compare.
I have 2 questions :
1) Do I Have to Erase the sector before writing. I ask this because it make much time, for example erase a 4K flash takes 400 ms, while writing 256 bytes taks 1.1 ms.
2) As writing disable Flash access, how can I know I my code is executed from flash or RAM ?
Thanks.
