Respected colleagues,
can anybody please post a sample on how to configure a uVision4 project for use of an external SRAM for data storage on the Keil MCB2929 evaluation board? Do I have to configure a Static Memory Controller (SMC) (and how?), or is it sufficient to configure Memory Areas in the Device Target Options?
Thanks in advance.
With best regards, Dragan Kujovic
http://www.keil.com/mcb2929/quickstart_mcb2929.pdf
Thank you, but there is no anwser on how to configure external SRAM on MCB2929 EVB in the PDF document you pointed out and in corresponding code examples.
www.keil.com/.../mcb2929_to_ext_ram.htm
Can anyone please post an example how to access external SRAM on MCB2929 evaluation board?
Anyone from KEIL staff?
Thanks in advance, Dragan Kujovic
How else is the chip going to know about your external hardware?
"and how?"
The Datasheet (and/or User Manual) for the particualr chip will tell you that.
For specific details of this particular NXP chip, you need to refer to the NXP documentation.
Have you looked at the NXP website for examples, tutorials, etc?
Besides SMC configuration, what else I have to set in the uVision project to access SRAM memory on the Keil MCB2929 evaluation board?
It should be normal for a hardware manufacturer (read Keil) to make a brief examples for every part of the hardware like they did for USB, etc.
Here is a function that I wrote for SMC setup:
void SMC_Setup(void) {
// ======================= // SMC Address lines setup // ======================= SFSP1_0 = (0x01<<2)|(0x03<<0); // Port 1.0 - Ext.Bus A.0 SFSP1_1 = (0x01<<2)|(0x03<<0); // Port 1.1 - Ext.Bus A.1 SFSP1_2 = (0x01<<2)|(0x03<<0); // Port 1.2 - Ext.Bus A.2 SFSP1_3 = (0x01<<2)|(0x03<<0); // Port 1.3 - Ext.Bus A.3 SFSP1_4 = (0x01<<2)|(0x03<<0); // Port 1.4 - Ext.Bus A.4 SFSP1_5 = (0x01<<2)|(0x03<<0); // Port 1.5 - Ext.Bus A.5 SFSP1_6 = (0x01<<2)|(0x03<<0); // Port 1.6 - Ext.Bus A.6 SFSP1_7 = (0x01<<2)|(0x03<<0); // Port 1.7 - Ext.Bus A.7 SFSP0_10 = (0x01<<2)|(0x03<<0); // Port 0.10 - Ext.Bus A.8 SFSP0_11 = (0x01<<2)|(0x03<<0); // Port 0.11 - Ext.Bus A.9 SFSP0_12 = (0x01<<2)|(0x03<<0); // Port 0.12 - Ext.Bus A.10 SFSP0_13 = (0x01<<2)|(0x03<<0); // Port 0.13 - Ext.Bus A.11 SFSP0_14 = (0x01<<2)|(0x03<<0); // Port 0.14 - Ext.Bus A.12 SFSP0_15 = (0x01<<2)|(0x03<<0); // Port 0.15 - Ext.Bus A.13 SFSP0_18 = (0x01<<2)|(0x03<<0); // Port 0.18 - Ext.Bus A.14 SFSP0_19 = (0x01<<2)|(0x03<<0); // Port 0.19 - Ext.Bus A.15 SFSP0_20 = (0x01<<2)|(0x03<<0); // Port 0.20 - Ext.Bus A.16 SFSP0_21 = (0x01<<2)|(0x03<<0); // Port 0.21 - Ext.Bus A.17 SFSP0_22 = (0x01<<2)|(0x03<<0); // Port 0.22 - Ext.Bus A.18 SFSP0_23 = (0x01<<2)|(0x03<<0); // Port 0.23 - Ext.Bus A.19
// ==================== // SMC Data lines setup // ==================== SFSP1_14 = (0x01<<2)|(0x03<<0); // Port 1.14 - Ext.Bus D.0 SFSP1_15 = (0x01<<2)|(0x03<<0); // Port 1.15 - Ext.Bus D.1 SFSP1_16 = (0x01<<2)|(0x03<<0); // Port 1.16 - Ext.Bus D.2 SFSP1_17 = (0x01<<2)|(0x03<<0); // Port 1.17 - Ext.Bus D.3 SFSP1_18 = (0x01<<2)|(0x03<<0); // Port 1.18 - Ext.Bus D.4 SFSP1_19 = (0x01<<2)|(0x03<<0); // Port 1.19 - Ext.Bus D.5 SFSP1_20 = (0x01<<2)|(0x03<<0); // Port 1.20 - Ext.Bus D.6 SFSP1_21 = (0x01<<2)|(0x03<<0); // Port 1.21 - Ext.Bus D.7 SFSP2_0 = (0x01<<2)|(0x03<<0); // Port 2.0 - Ext.Bus D.8 SFSP2_1 = (0x01<<2)|(0x03<<0); // Port 2.1 - Ext.Bus D.9 SFSP2_2 = (0x01<<2)|(0x03<<0); // Port 2.2 - Ext.Bus D.10 SFSP2_3 = (0x01<<2)|(0x03<<0); // Port 2.3 - Ext.Bus D.11 SFSP2_4 = (0x01<<2)|(0x03<<0); // Port 2.4 - Ext.Bus D.12 SFSP2_5 = (0x01<<2)|(0x03<<0); // Port 2.5 - Ext.Bus D.13 SFSP2_6 = (0x01<<2)|(0x03<<0); // Port 2.6 - Ext.Bus D.14 SFSP2_7 = (0x01<<2)|(0x03<<0); // Port 2.7 - Ext.Bus D.15
// ======================= // SMC Control lines setup // ======================= SFSP1_12 = (0x01<<2)|(0x03<<0); // Port 1.12 - Ext.Bus OE# SFSP1_13 = (0x01<<2)|(0x03<<0); // Port 1.13 - Ext.Bus WE# SFSP2_14 = (0x01<<2)|(0x03<<0); // Port 2.14 - Ext.Bus BLS0# SFSP2_15 = (0x01<<2)|(0x03<<0); // Port 2.15 - Ext.Bus BLS1# SFSP1_8 = (0x01<<2)|(0x03<<0); // Port 1.8 - Ext.Bus CS0# //SFSP1_9 = (0x01<<2)|(0x03<<0); // Port 1.9 - Ext.Bus CS1# //SFSP1_10 = (0x01<<2)|(0x03<<0); // Port 1.10 - Ext.Bus CS2# //SFSP1_11 = (0x01<<2)|(0x03<<0); // Port 1.11 - Ext.Bus CS3# //SFSP1_22 = (0x01<<2)|(0x03<<0); // Port 1.22 - Ext.Bus CS4# //SFSP1_23 = (0x01<<2)|(0x03<<0); // Port 1.23 - Ext.Bus CS5# //SFSP3_0 = (0x01<<2)|(0x03<<0); // Port 3.0 - Ext.Bus CS6# //SFSP3_1 = (0x01<<2)|(0x03<<0); // Port 3.1 - Ext.Bus CS7#
// ======================= // SMC Memory Bank 0 Setup // ======================= SMC_IDCYR0 = 0x0F; // Idle-cycle control register SMC_WST1R0 = 0x1F; // Wait-state 1 control register SMC_WST2R0 = 0x1F; // Wait-state 2 control register SMC_WSTOENR0 = 0x00; // Output-enable assertion delay control register SMC_WSTWENR0 = 0x01; // Write-enable assertion delay control register SMC_CR0 = 0x80; // Configuration register SMC_SR0 = 0x00; // Status register
A question for the hardware manufacturer Keil?
Or for the hardware manufacturer NXP?
After all, it's mainly the chip manufacturer who should supply sample code for how to use their processors.
Yes, for Keil because they are selling a MCB2929 evaluation board under their trademark.
If you purchase a car, you do not care who is the manufacturer of the processor in the board computer, you ask everything the car manufacturer.
Your analogy with a car fails badly. If you buy a car, you are normally an end user intending to use the car for transport. You don't buy it as a evaluation/development kit.
If you buy a development board, the development board is not intended for end user mass products. You normally buy a development board to get a soldered copy of a processor you want to experiment with.
For things built into the processor (UART, SPI, ...) it would then normally be the CPU manufacturer who should supply examples how to use them.
For external hardware, like a display connected to the CPU, it should normally be the board manufacturer, as integrator, who should spend time documenting the design and how to access the display.
When interfacing external RAM to a processor, it's normally the CPU manufacturer who have to be the main source of information how to do it.
Having the board manufacturer supplying a large number of sample code that can be directly compiled is of course a bonus. But not a primary goal with a development board. That is also the reason why many CPU manufacturers explicitly buys services from board manufacturers to create reference boards - because the CPU manufacturer is responsible for supplying documentation/samples while a manufacturer of compilers and development boards have the supply chain for distributing adapted sample code with the boards. Remember that without explicit backing from the chip manufacturers, the board manufacturers will not have access to any more information than you, as CPU buyer, also have access to.
But back to your car analogy - how many car manufacturer have you seen that sells evaluation kits/development kits for allowing a buyer to experiment with a specific break system, V8 engine or air condition?
As you said, this was analogy. But, at the bottom line, it seems that nobody on this forum doesn't know how to use external SRAM on MCB2929 EVB. Maybe, even the Keil programmers haven't tested the external SRAM on their own evaluation board.
Am I right, or am I right?
Respected Colleagues,
because nobody from Keil stuff and from this Forum wanted to help me with SRAM access on the Keil MCB2929 Evaluation Board, I wrote a needed code. Everything works OK.
Here it is if somebody need it.
/*****************************************************************************************/ /* Keil MCB2929 Evaluation Board SRAM Access Example - Dragan Kujovic 18.11.2010. /*****************************************************************************************/
#include "LPC29xx.h"
#define EXT_SRAM_BaseAddress 0x40000000 #define Mem_16(adr) (*((volatile unsigned short *) (adr)))
unsigned short Ext_SRAM_Data = 12345; unsigned int Ext_SRAM_Address = 0x00; unsigned short Value = 0;
SMC_Setup(); // Static Memory Controller Init
// Only EVEN Addresses are valid !!! (Every 2nd Address)
SRAM_WordWrite(Ext_SRAM_Data, Ext_SRAM_Address);
Value = SRAM_WordRead (Ext_SRAM_Address);
// SMC Control lines setup // ======================= SFSP1_8 = (0x01<<2)|(0x03<<0); // Port 1.8 - Ext.Bus CS0# SFSP1_12 = (0x01<<2)|(0x03<<0); // Port 1.12 - Ext.Bus OE# SFSP1_13 = (0x01<<2)|(0x03<<0); // Port 1.13 - Ext.Bus WE# SFSP2_14 = (0x01<<2)|(0x03<<0); // Port 2.14 - Ext.Bus BLS0# SFSP2_15 = (0x01<<2)|(0x03<<0); // Port 2.15 - Ext.Bus BLS1#
// SMC Memory Bank 0 Setup // ======================= SMC_IDCYR0 = 0x0F; // Idle-cycle control register (Reset value = 0x0F) SMC_WST1R0 = 0x03; // Wait-state 1 control register (Reset value = 0x1F) SMC_WST2R0 = 0x03; // Wait-state 2 control register (Reset value = 0x1F) SMC_WSTOENR0 = 0x02; // Output-enable assertion delay control register (Reset value = 0x00) SMC_WSTWENR0 = 0x02; // Write-enable assertion delay control register (Reset value = 0x01) SMC_CR0 = 0x40; // Configuration register (16-bit) (Reset value = 0x80)
void SRAM_WordWrite(unsigned short SRAM_Data, unsigned int CurrentAddress) {
Mem_16(EXT_SRAM_BaseAddress + CurrentAddress) = SRAM_Data;
unsigned short SRAM_WordRead (unsigned int CurrentAddress) {
static unsigned short SRAM_Data;
SRAM_Data = Mem_16(EXT_SRAM_BaseAddress + CurrentAddress);
return SRAM_Data;
Three things:
1) This is a end user forum. Keil stuff [sic!] don't normally read posts here. They have specific contact information available to reach their support.
2) And a large percentage of the people who do have the skills to help on this forum, are quite busy with their own projects, since they are commercial developers.
3) Have you checked that you don't have a startup file that already contains support for external memory? The file LPC29xx.s does seem to contain the definitions, to use the Keil Configuration Wizard to configure memory access.
Without opening the projects, it looks like some of the examples for the MCB2929 does configure external memory in the LPC29xx.s file.
A question here - did you look into the startup file before starting to write C code?
