Hi ! I have a mcb2300.
I made the test with the SD_File demo. When I reset the target with the button, the app is unable to init the SD card (tried many times). If I to reinsert the SD card and relaunch initialization, the SDcard init is successful. If I power OFF/ON the target the SDcard init is successful.
File_config.c is version 3.70.
That's annoying when the code may reset by watchdog, and nobody can access the stuff to reinsert the card.
Thanks for any response.
You should first try the latest RL version (v4.12).
Where do I get it ? From the eval software ? I have a license so I'm not sure I can freely update my RL lib ?
Unfortunately you would have to have to still be in 1 year period from when you bought RL or buy an Upgrade, contact Keil support for details.
it works when you remove & re-insert the card; it works when you power-cycle the board; it doesn't work when you just reset the processor.
So the problem occus when the processor resets without a power-cycle at the card?
I think you need to look carefully at how you initialise the card at startup...
"That's annoying when the code may reset by watchdog, and nobody can access the stuff to reinsert the card."
I don't think these boards are designed for shipping to your customers?
If you are a licensed customer, then you should be speaking direct to Keil support!
So the problem occus when the processor resets without a power-cycle at the card? Surely
I don't think these boards are designed for shipping to your customers? You mean that the pb is due to the board design ?
In fact I wrote to keil, but still waiting for answer ... So I tried here.
I hope that the board design is lead-free
