Problems with c++ classes
first of all I would like you to know a little bit about the project I'm doing (can't tell much:).
I am building a system in which I'd like to have a menu implemented as some kind of a finite state machine.
The menu should be able to be nested.
I would like the code for it to be very simple, something like this:
MENU menu;
MENU m1(&menu);
MENU m2(&menu);
MENU m11(&m1);
MENU m21(&m2);
MENU m22(&m2);
MENU m23(&m2);
This code should give me the menu that is nested and looks like this:
MENU---
M1     M2---
M11    M21  M22
I made a C++ code that works in Visual Studio 2010, but when I tried to migrate it to Keil uVision and put it on a microcontroller, it compiles well, but it blocks before entering the main().
I read that it is generally not a good idea to use dynamic memory allocation in embedded systems, and I don't really need dynamic allocation of memory for the menu, since it will be static, and defined at compiling.
But I would really like to use class approach to it.
To give you another example: i implemented button matrix as a class, so it can easily be defined this way:
        ButtonNetwork BN;
        BN.AddOutLine(LPC_GPIO0, 26);
        BN.AddOutLine(LPC_GPIO0, 25);
        BN.AddOutLine(LPC_GPIO0, 24);
        BN.AddInputLine(LPC_GPIO3, 26);
        BN.AddInputLine(LPC_GPIO3, 25);
        BN.AddInputLine(LPC_GPIO1, 18);
        BN.AddInputLine(LPC_GPIO1, 19);
This way I can define a button matrix very easy with 3 output lines, and 4 input lines.
Also the same problem - the number of lines will be static. I just prefer this approach, because it is easier for later changes to a software.
The microcontroller I use is LPC1768 Cortex M3.
Please tell me what is the easiest way to make it work.
As a temporary solution, I tried increasing the heap size but it doesn't help.
Ill wait for your answers before continuing with this,
Thanks for even reading.
