Hi everyone,
I am trying to come up with some macros to enable and disable all interrupts in my LPC2364 while using the Keil RTX and programming in uVision4. After searching through much of the knowledge base, I came across the macros IENABLE and IDISABLE.
unsigned char interrupts_enabled = 0; #define IENABLE __asm{ MRS LR , SPSR }; \ __asm{ STMFD SP! , {LR} }; \ __asm{ MSR CPSR_c , #0x1F }; \ __asm{ STMFD SP! , {LR} }; \ interrupts_enabled = 1; #define IDISABLE __asm{ LDMFD SP! , {LR} }; \ __asm{ MSR CPSR_c , #0x92 }; \ __asm{ LDMFD SP! , {LR} }; \ __asm{ MSR SPSR_cxsf , LR }; \ interrupts_enabled = 0;
Most of that code is a mix of what is suggested in the following links:
http://www.keil.com/support/docs/2910.htm http://www.keil.com/support/man/docs/armcc/armcc_cihccdja.htm http://www.keil.com/support/man/docs/armcc/armcc_Chdgbbia.htm
However, I think I am having a problem due to Virtual Registers. As per the third reference above, we are not allowed to access the LR, SP and PC registers directly. That is the reason why, obviously, I get errors such as the following:
..\RF\mrfi\radios\common\mrfi_f1f2.c(242): error: #20: identifier "LR" is undefined
These instructions that access the LR and SP registers are quite significant in what I am trying to achieve though. How can I express this behavior in terms of what inline assembly can do for me? Has anyone done anything like this before, for enabling/disabling interrupts in a LPC microcontroller?
