RL-FlashFS: How to determine the length of a file
Hi all,
when I try to determine the lenhth of a file I use following code:
int  flength(char *filename)
FILE* file;
FINFO info;
  file = fopen(filename,"r");
  if(!file)
    return(-1);
  fclose(file);
  info.fileID = 0;
  while(ffind(filename, &info)==0);
  if(info.fileID == 0)
    return(-1);
  return(info.size);
All works fine as long as I use simple filenames like "F:test.txt".
As soon as I try to do this with filenames including subfolders ("F:\\test\\test.txt") it fails.
Is there another way to determine the length of a file?
Why won't ffind() not work with subfolders?
Any ideas?
Marco
