Its there any function to obtain my IP, cause I know my IP but I can't know if I get the good IP with DHCP, should I read in the config file the _IP1 _IP2....? cause they are only #define and in the tcpsocket and in none structure theres the actual IP.
Thank you for your help
Variable is declared in net_config.c
To access it use something like:
localm[NETIF_ETH].IpAdr
Thanks I found the instruction....
