Hi all,
I'm writing code to be included in a larger project with an external vendor.
The vendor doesn't what to share their source with me but I need the functions implemented in their code to compile an run my piece for development and testing.
I think they can create a library or compiled version of their code (protecting their IP) that I can then include in my project, compile and test.
I'm sure this is a common situation but have some concerns about shared memory, ROM space etc.
Please can someone point me to the right documentation on how to achieve this?
Many thanks,
Malcom.
That looks rather more complicated than just having a "normal" Library, and linking to it in the "normal" way?
www.keil.com/.../uv4_ca_createlibraryfile.htm
Not sure whether the below link is related to this topic.
Multi-Application Programming for ARM
The example shows how you can split a project into two parts that can be developed independent from each other.
http://www.keil.com/download/docs/324.asp
Take a look at how Keil do ST's "standard peripheral library" for their STM32: it is supplied as both source and a ready-built library...
