I am trying to define a 64 byte memory block in RAM to hold some variables that need to be initialised. I would like to have the rest (unused) bytes of the 64 byte block to be "filled" with 0xFF. The general idea is to have a RAM image of an EEPROM's data page.
I have checked things out and I think it should be possible using a custom scatterfile by using the "FILL" attribute.
However, I get an unexpected error message (see below). From it I deduce it considers the "EEPROM_APP_PAGE_01" section to be "EMPTY" but I do not know why. More importantly: I can't find how to tell it that the section in question should not be considered "EMPTY" but should be filled instead.
Does anyone have any suggestion(s) as to what I am doing wrong or overlooking ?
Any help much appreciated, Filip
This is the "C" code to declare the variable(s) in the "app_eeprom_def.c" file.
//*************** EEPROM page 01: begin****************************************/ #pragma arm section rwdata = "EEPROM_APP_PAGE_01", zidata = "EEPROM_APP_PAGE_01" unsigned short test = 0x55AA; //*************** EEPROM page 01: end *****************************************/
This is the scatter file:
LR_IROM1 0x00000000 0x00040000 { ; load region size_region ER_IROM1 0x00000000 0x00040000 { ; load address = execution address *.o (RESET, +First) *(InRoot$$Sections) .ANY (+RO) } RW_IRAM1 0x10000000 0x00008000 { ; RW data .ANY (+RW +ZI) } RW_IRAM2 0x2007C000 0x00007AC0 { ; RW data .ANY (+RW +ZI) } EEPROM_APP_PAGE_01 0x20083AC0 FILL 0xFFFFFFFF 0x40 { ; RW data app_eeprom_def.o (EEPROM_APP_PAGE_01) } }
This the error I am getting:
.\Flash\Q1CMCDVB.sct(24): error: L6175E: EMPTY region EEPROM_APP_PAGE_01 cannot have any section selectors.
