Hi all,
I'm using Keil RV4.10 on MCBSTM32 demo board (STM32F103RB) with STM32F10x_StdPeriph_Lib_V3.1.2 and Keil RTX kernel.
My application is relocated at 0x8002800 (bootloader and configuration data are placed before).
My main just setup the clock, peripherals, interrupts, etc ... and call
os_sys_init
All seems to be ok.
Recently I had to add in infinite cicle for debug/test purposes just after clocks and irq setup, like this:
int main(void) { MicroController.Setup(); //setup clock, preiphs, irq,... while(1) { IWDG_ReloadCounter(); //DEBUG } os_sys_init(FirstTask); }
then something strange happens... during the while(1) loop the application goes into HardFault_Handler, and the debugger shows me the following call stack:
HardFault_Handler() rt_put_rdy_first() rt_systick() HAL_CM3() rt_systick()
Could this be related to the RTX kernel ?
What's happening ? Am I not allowed to do whatever I want before calling
Hi Robert,
you're right, that was my guess too. I found that systick is configured and used by our bootloader. There is no library function to turn it off, so I simply add
SysTick->CTRL &= ~1
as the first main instruction. Problem solved, I'll put this instruction at the end of our bootloader process for next revision. Thanks.
My guess is somehow the system_tick timer is getting initialized BEFORE the OS has been initialized. Try not initializing the system_tick timer (RTX does initialize this timer)
Jed C,
thanks for the links, but they didn't help. I do have a large-enough main stack, my code is all privileged, and all my setup activities uses global or setup-local variables, so the stack is clean after hw initialization. Furthermore, there are no problems if I don't put an endless loop before the os_sys_init call, and the loop itself consumes very little stack... So it seems a matter of ''how long'' I indulge in the main before calling os_sys_init... From the call stack seems that the os is trying to schedule, but ther's nothing to schedule yet... hence the hardfault...
Any more specific hint ?
These links may provide you with the info you need to answer your question....
What happens within startup code: www.embedded.com/.../200900043
RTX startup: www.keil.com/.../rlarm_ar_hints_cortex.htm
-OR-
http://www.keil.com/support/man/docs/rlarm/rlarm_ar_hints_arm.htm
