Hi, Guys
I got this code from my internet and it is written using IAR C from IAR then I want to compie it in KEIL but after compiling it I got alot of errors from compiling from KEIL
Would you check it?
<C:\IAR\KEIL\PROJET\SOURCE.C.ZIP.RAR>
after making some research I saw that the code is written under IAR Compiler but there are still some errors can you check it?
then the errors are at lines:
1 expression required 279 expression required 1300 expression required 7323 expression required 9346 expression required 10269 expression required 15269 expression required 27269 expression required
I am waiting your replies
So give it an expression, then!
With a source file that's got as many lines as indicated (27269), a suitable expression might be:
"Abandon hope, all ye who enter here"
I only correct Internet code once it reaches 100000 lines. sorry, maybe next time.
... at the bargain rate of just GBP 1.00 (one pound sterling) per source line.
from my internet Would you check it? <C:\IAR\KEIL\PROJET\SOURCE.C.ZIP.RAR>
Sorry, I don't have your internet, I have a different one. Could you pls. copy it to mine?
Different toolchains have different speciallities. Not all code is compileable through all the toolchains, i.e. ARM, IAR, gcc, ...
. Some parts you'll have to port, especially the startup section and compiler intrinsics (i.e. __NOP() )
. BR, /th.
my code???
how do you plan us to get at your C drive
I checked my computer and I don't even have:
Is that weird or what?
--Cpt. Vince Foster 2nd Cannon Place Fort Marcy Park, VA
Seems perfectly normal to me - none of my computers has it!
I think we need to arrange a brainstorming session to solve this urgent problem.
Do not install this file on your computer. It is a probably a virus that is installed with the IAR tools! They call it KEIL because that way lots of people will use it. :-)
Jon
ahh, I got it, two files:
resolve to:
C:\KEIL\PROJET\SOURCE.C.RAR C:\IAR\PROJET\SOURCE.C.ZIP
But - there's still the problem thet the files are on his internet.
and, it seems, that is where they're going to stay.
He seems to have no real interest in this.
