PROBLEM WITH COMPILING. check my code
Hi, Guys
I got this code from my internet and it is written using IAR C from IAR then I want to compie it in KEIL but after compiling it I got alot of errors from compiling from KEIL
Would you check it?
<C:\IAR\KEIL\PROJET\SOURCE.C.ZIP.RAR>
after making some research I saw that the code is written under IAR Compiler but there are still some errors can you check it?
then the errors are at lines:
1 expression required
279 expression required
1300 expression required
7323 expression required
9346 expression required
10269 expression required
15269 expression required
27269 expression required
I am waiting your replies
  • Hi,
    from my internet
    Would you check it?
    Sorry, I don't have your internet, I have a different one. Could you pls. copy it to mine?
    Different toolchains have different speciallities. Not all code is compileable through all the toolchains, i.e. ARM, IAR, gcc, ...
    Some parts you'll have to port, especially the startup section and compiler intrinsics (i.e. __NOP() )
    BR,
    /th.
  • Hi,
    from my internet
    Would you check it?
    BR,
    /th.
