Hi ! I'am compiling a TCP application based on the http demo. My problem is that the application is not responding to ARP request, as it if was dead. Indeed, I've put a led toggle in timer_task and tcp_task and they are alive. I've tested many thing : Put init_TCPnet() before os_init() Use Round-Robin put tcp_get_socket in the main()
Here is the code of my main.c :
#include <RTL.h> #include <stdio.h> #include <LPC23xx.H> #include "ui/ui.h" #include "led/led.h" // Define here the priority for your task //! Init Task must have the higher priority #define PRIO_INIT 100 #define PRIO_TIMER_TSK 30 #define PRIO_UI_TSK 1 #define PRIO_CONTROL_LOOP 99 //! stack for the ui task /*! howto declare : see os_tsk_create_user. */ U64 g_ui_stack[800/8]; __task void init (void) ; int main (void) { /* Start with 'init' task. */ os_sys_init(init); while(1); } __task void init (void) { /* Add System initialisation code here */ init_TcpNet (); LED_Init() ; LED_Out(0) ; /* Initialize Tasks */ os_tsk_prio_self (PRIO_INIT); // Set ourself to higher priority os_tsk_create (ui_timer_task, PRIO_TIMER_TSK); os_tsk_create_user (ui_task, PRIO_UI_TSK, &g_ui_stack, sizeof(g_ui_stack)); os_tsk_delete_self(); // delete myself and start other task execution. }
Here is the code for my ui :
#include <RTL.h> #include <Net_Config.h> #include <string.h> #include "ui.h" #include "led/led.h" //! Order received by GUI & target returns typedef enum { STOP = 0, //!< Stop experience LAST } T_ORDER; //! Define parameters for a task typedef struct { U32 uiEnable ; ... } T_TASK_PARAM ; // Order + size fields #define FRAME_HEADER_SIZE 8 //! Structure of the Received orders. typedef struct { T_ORDER order; ... } T_CLIENT_FRAME ; //! Sent Frame typedef struct { U32 uiOSClock ; ... } T_SERVER_FRAME ; #define NB_CONTROL_LOOP 10000 //! GUI socket static U8 g_socket_tcp; static T_CLIENT_FRAME g_ClientFrame ; static T_SERVER_FRAME g_ServerFrame ; static U8 g_BytesRead ; U16 ui_callback (U8 soc, U8 evt, U8 *ptr, U16 par) ; static void tcp_launch_tasks(void) ; static void tcp_stop_tasks(void) ; static void tcp_send_data(void) ; #ifndef htonl #define htonl(a) \ ((((a) >> 24) & 0x000000ff) | \ (((a) >> 8) & 0x0000ff00) | \ (((a) << 8) & 0x00ff0000) | \ (((a) << 24) & 0xff000000)) #endif #ifndef ntohl #define ntohl(a) htonl((a)) #endif #ifndef htons #define htons(a) \ ((((a) >> 8) & 0x00ff) | \ (((a) << 8) & 0xff00)) #endif #ifndef ntohs #define ntohs(a) htons((a)) #endif __task void ui_task (void) { unsigned int i = 0 ; g_BytesRead = 0 ; memset(&g_ClientFrame, 0, sizeof(g_ClientFrame)) ; memset(&g_ServerFrame, 0, sizeof(g_ServerFrame)) ; /* Initialize TCP server Socket and start listening */ g_socket_tcp = tcp_get_socket (TCP_TYPE_SERVER, 0, UI_SOCKET_TIMEOUT, ui_callback); if (g_socket_tcp != 0) { tcp_listen (g_socket_tcp, PORT_NUM); while (1) { main_TcpNet() ; os_tsk_pass() ; // schedule ++i ; if (i > 100000) { LED_Toggle (1) ; i = 0 ; } } } } __task void ui_timer_task (void) { /* System tick timer task */ os_itv_set (10); while (1) { timer_tick () ; os_itv_wait (); // Wait and schedule LED_Toggle (0) ; } } static void ui_process_frame (void) { // Toogle led LED_Toggle (1) ; // convert indianness g_ClientFrame.order = (T_ORDER) ntohl(g_ClientFrame.order) ; g_ClientFrame.size = ntohl(g_ClientFrame.size) ; switch(g_ClientFrame.order) { case START : // only convert data to be interpreted ... tcp_launch_tasks() ; break ; case STOP : tcp_stop_tasks() ; break ; case DATA : tcp_send_data() ; } } U16 ui_callback (U8 soc, U8 evt, U8 *ptr, U16 par) { /* This function is called by the TCP module on TCP event */ /* Check the 'Net_Config.h' for possible events. */ if (soc != g_socket_tcp) { return (0); } switch (evt) { case TCP_EVT_DATA: /* TCP data frame has arrived : We frame receive portion of the frame so we shall control data received ... break; case TCP_EVT_CONREQ: /* Remote peer requested connect, accept it if socket available */ switch( tcp_get_state(g_socket_tcp) ) { case TCP_STATE_CLOSED: case TCP_STATE_LISTEN: return (1); default : return 0 ; } case TCP_EVT_CONNECT: /* The TCP socket is connected */ return (1); case TCP_EVT_CLOSE : case TCP_EVT_ABORT : /* Keep the socket allocated for further connection */ break ; default: break ; } return (0); } static void tcp_launch_tasks(void) { } static void tcp_stop_tasks(void) { } static void tcp_send_data(void) { U8 * sendbuf ; U32 size = FRAME_HEADER_SIZE + g_ClientFrame.size ; g_ClientFrame.order = (T_ORDER) htonl(g_ClientFrame.order) ; g_ClientFrame.size = htonl(g_ClientFrame.size) ; // check socket availability if (tcp_check_send(g_socket_tcp) == __TRUE) { sendbuf = tcp_get_buf(size) ; memcpy(sendbuf,&g_ClientFrame,size) ; if ( tcp_send(g_socket_tcp, sendbuf, size) == __FALSE) { // hdle frame send error. } } // else abord sending... CAN add some code to place the frame in a buffer. }
I'm getting crazy comparing with http demo without find THE Difference !! Thanks for any help !
I have the answer. The solution is to add additionnal build option the LPC23_EMAC.c file, like in the http demo. I did not see such info in the getting started.
