I hope somebody can clarify this issue for me - I am sure it is somewhere in th ABI for it escapes me. Using ARM7 architecture (LPC2478), I have a function written in C that is called (BL) from the startup file. The problem is that the compiler does not generate a "BX LR" instruction at its end. Is there some limitation in place that I am not aware of?
I think this is a tool chain but - if I place the function that is called from startup code in a separate C module - a "BX LR" is generated!
"...the compiler does not generate a "BX LR" instruction at its end."
The only instance I know of where the compiler does not generate a return from a function is when it is an __asm function, so you add it to the function yourself.
If you look at the assembler produced for the C module, you surely see the returns in other functions?
Are you saying that your one C function just falls through to the next?
YES!
I will try to send this program to Keil so they can see it. This cause me SO MUCH heard ache today (when combined with other changes...).
"YES!"
OMG. Sounds nasty!
I reported a problem with compiler produced code a few weeks ago (-O3 was creating faulty inline code) and was told that there should be a compiler update around mid-October.
Mid-October? First it was mid-September, then beginning October, and now this...
And you're sure that's not just because the compiler inlined that function, and thus there was no need to return from it?
A little actual source and actual assembler output of both that function and its caller would go a long way towards clarifying this puzzle...
Well, another good reason for a compiler to omit a return from a function is the case when the function doesn't ever return, like a typical main(). So yes, some actual source code would be in order.
Mike,
I have an enormous amount of work now. I will try to post a code snippet in the very near future.
"Well, another good reason for a compiler to omit a return from a function is the case when the function doesn't ever return, like a typical main()."
A valid point, I'd forgotten that one.
> Well, another good reason for a compiler to omit a return from a function is the case when > the function doesn't ever return, like a typical main().
Or in case the compiler applied tail-call optimization.
int var; int bar() { return var; } int foo() { return bar(); }
(assuming the compiler doesn't inline this silly example)
-- Marcus http://www.doulos.com/arm/
