.hex to .bin conversion
IS there anyboby knows how to automatically convert the .hex file outputted by keil to .bin file for flashing..
I tried to use the hex2bin software utility, but the output is too large around 128MB. and the ST-link would stuck up every time i load the bin file into it. I tried to use the options but none to avail. Please help.
Thank you,
j
  • A bin file doesn't have any holes in it.
    So if you configure your hex file to contain data at two separate memory regions with 12MB gap between, you will get a huge bin file.
    If having separate memory regions in the chip, then you must create multiple bin files to avoid the problem with the gap between the regions.
