Could someone please help me in clarifying that weird execution sequence of the following function:
int S2Pressed (void) { static int S2KeyCount = 0, S2KeyPressed = 0; 01 if (S2KeyPressed) { 02 if (((GPIOA->IDR & S2) == 0 )) { // Check if S2 is pressed 03 if (S2KeyCount < UNBOUNCE_CNT) S2KeyCount++; 04 else { 05 S2KeyPressed = 1; 06 S2KeyCount = 0; 07 return (1); 08 } 09 } 10 } 11 else { 12 if (!((GPIOA->IDR & S2) == 0 )) { // Check if S2 is not pressed 13 if (S2KeyCount < UNBOUNCE_CNT) S2KeyCount++; 14 else { 15 S2KeyPressed = 0; 16 S2KeyCount = 0; 17 } 18 } 19 } 20 return (0); } <pre/> When I simulate the code, it enters the function on line 01 then jump to line 03, then jump back to line 02, then again to line 03, then back to line 02, and then directly jumps to line 12 then 20 and exit that function. It looks like it doesn't matter what is inside the if/else statement because it always does the same with the exact sequence (01, 03, 02, 03, 02, 12), No matter whether I replace the code of the outer if<i/> from line 02 to 09 with the one of the else<i/> part (from line 12 to 18). Now the weird thing is that I have copied that function from the ~Keil\Boards\MCBSTM32\GPIO\GPIO.uvprog When I simulate the latter program it runs just fine without any problems! Can anyone give me any hint one how to move to solve this issue! Any help would be appreciated
Probably compiler optimization. What does the underlying assembly code tell you?
Seconded.
Note that, even without optimisation, the operation sequence does not have to follow the sequence of the high-level language (HLL) source lines.
eg, the control logic for a HLL 'for' loop is often implemented at the end of the loop - so stepping will seem to go the the end of the loop first...
