Timer T2
Hey,
I want to use timer T2 for some function which will generate a delay of 1ms.So i loaded values equivalent to 1000 counts into TMH2 and TML2.But my doubt is Three capture registers were already used for loading the interrupt addresses of 3 other functions.Is it possible to still use timer T2 (TMH2 and TML2) though capture registers CT0,CT1 and CT2 are already used.Since i read in the data sheet of the microcontroller that "These registers are loaded with the contents of T2 and an interrupt is requested upon receipt of the input signals CT0I, CT1I, CT2I or CT3I."I am using 80c552.Please help.
