Assembler problems - I don't know why are this problems! If someone could correct this lines it would help me alot!
- start.asm(12): error: identifier "$EXTEND2" is undefined
$EXTEND2
- start.asm(14): error: expected a ";"
$GENONLY
- start.asm(20): error: unrecognized token
@SET( BIT_INIT, 0 ) //; disable(0)/enable(1) initialization of bit
- start.asm(32): error: too many characters in character constant
__CSTART_PR SECTION CODE WORD PUBLIC 'CPROGRAM'
- start.asm(38): error: "#" not expected here - start.asm(40): error: "#" not expected here - start.asm(41): error: "#" not expected here
MOV VECSEG, #(0xC00000>>16) //; Set vector table segment ATOMIC #3 (this one is OK? Why?) MOV SP, #SOF ?SYSSTACK_TOP //; Set stack pointer. MOV STKOV, #SOF ?SYSSTACK_BOTTOM + 6*2 //; Set stack overflow pointer.
- start.asm(69): error: unrecognized token
@_CALL(__C_INIT, R1) //; initialization of global/static data
- start.asm(93): error: too many characters in character constant
C166_US SECTION LDAT WORD GLBUSRSTACK 'CUSTACK'
. . . . start.asm
////;; ////;; C166/ST10 startup code generated by EDE for project singlemotor_foc_64mhz ////;; ////;; If modifications are needed, disable generation of the startup code in EDE: ////;; In the EDE Project Options dialog select Application, and then Startup. Make ////;; sure the checkbox 'Generate system startup code and add it to project' is not ////;; checked. Note that changes in EDE will now no longer be reflected in the ////;; startup code. Also be aware that the modifications will be overwritten when ////;; the checkbox is enabled again. ////;; $EXTEND2 $CASE $GENONLY $NOLOCALS $CHECKCPU16 $CHECKBUS18 $NOMOD166 ////; disable the internal set of SFRs $STDNAMES(regxe164f.def) //; define SFRs @SET( BIT_INIT, 0 ) ////; disable(0)/enable(1) initialization of bit //; variables at startup $INCLUDE(head.asm) //; Generic definitions (see product include dir) $INCLUDE(_c_init.asm) //; Initialize C variables NAME CSTART //; module name PUBLIC __IDLE //; cstart end PUBLIC __EXIT //; address to jump to on 'exit()' EXTERN _main:FAR //; start label user program EXTERN __C_INIT:FAR __CSTART_PR SECTION CODE WORD PUBLIC 'CPROGRAM' __CSTART PROC TASK __CSTART_TASK INTNO __CSTART_INUM = 0 DISWDT //; Disable watchdog timer MOV VECSEG, #(0xC00000>>16) //; Set vector table segment ATOMIC #3 MOV SP, #SOF ?SYSSTACK_TOP //; Set stack pointer. MOV STKOV, #SOF ?SYSSTACK_BOTTOM + 6*2 //; Set stack overflow pointer. MOV STKUN, #SOF ?SYSSTACK_TOP //; Set stack underflow pointer. MOV CP, #CSTART_RBANK //; Set context pointer. NOP MOV DPP0, #PAG ?BASE_DPP0 //; Set data page pointer. MOV DPP1, #PAG ?BASE_DPP1 //; Initialise these before we can make a MOV DPP2, #PAG ?BASE_DPP2 //; user stack call below //; Set user stack pointer //; To avoid problems when the userstack is located at the end of a page, the //; initial value is set using base + size. MOV R0, #?USRSTACK_BOTTOM + (?USRSTACK_TOP - ?USRSTACK_BOTTOM) BFLDH PSW, #3, #2 //; set local register bank 0 (10) MOV R0, #?USRSTACK0_BOTTOM + (?USRSTACK0_TOP - ?USRSTACK0_BOTTOM) BFLDH PSW, #3, #3 //; set local register bank 1 (11) MOV R0, #?USRSTACK1_BOTTOM + (?USRSTACK1_TOP - ?USRSTACK1_BOTTOM) BFLDH PSW, #3, #0 //; set to global user stack EINIT //; End of initialization @_CALL(__C_INIT, R1) //; initialization of global/static data BSET IEN //; allow monitor to break application MOV R12, #0 //; set argc to 0 MOV R13, #0 //; set argv[] to 0 MOV R14, #0 //; @_CALL( _main, R1) //; The exit() function causes normal program termination to occur. First, all //; functions registered by the atexit() function are called in the reverse //; order. Next, all open streams with unwritten buffered data are flushed, all //; open streams are closed and all files created by the tmpfile() function are //; removed. The status value passed to exit is returned in R4. __EXIT: LABEL FAR //; the exit() or abort() function jumps //; to this entry. __IDLE: IDLE //; Power down CPU until peripheral inter- //; rupt or external interrupt occurs. JMPR CC_UC, __IDLE //; set idle mode again. RETV //; Virtual return. __CSTART ENDP __CSTART_PR ENDS C166_US SECTION LDAT WORD GLBUSRSTACK 'CUSTACK' DS 2 //; Allocate a user stack of at least 2 bytes C166_US ENDS //; Define empty user stack used with localregister bank 0. C166_US0 SECTION LDAT WORD GLBUSRSTACK 'CUSTACK' C166_US0 ENDS C166_US1 SECTION LDAT WORD GLBUSRSTACK 'CUSTACK' C166_US1 ENDS C166_US2 SECTION LDAT WORD GLBUSRSTACK 'CUSTACK' C166_US2 ENDS C166_SYSSTACK SECTION HDAT WORD SYSSTACK DS 512 * 2 //; Reserve stack size in words C166_SYSSTACK ENDS SSKDEF 7 //; System stack size CSTART_RBANK REGDEF R0-R15 //; Register usage END
I have this files and also I can add START_V3.A66 to the project. Start.asm I kicked out of the project. So It should be running. Or how I have to understand your comment.
SINGLEMOTOR_FOC_64MHZ.ASM I also modefi it but it is not the porblem.
MAIN.H
MAIN.C
SCS.H
SCS.C
XE16XREGS.H
IO.H
IO.C
GPT2.H
GPT2.C
CC2.H
CC2.C
CCU60.H
CCU60.C
ADC0.H
ADC0.C
CAN.H
CAN.C
INT.H
INT.C
The startup seems to have been generated by EDE (Tasking compiler) and can not be compiled by a Keil compiler.
I would suggest generating a Startup-Code with the Keil compiler.
