assembler problems xe164f in Keil uVision4
Assembler problems - I don't know why are this problems! If someone could correct this lines it would help me alot!
- start.asm(12): error: identifier "$EXTEND2" is undefined
$EXTEND2
- start.asm(14): error: expected a ";"
$GENONLY
- start.asm(20): error: unrecognized token
@SET( BIT_INIT, 0 )                     //; disable(0)/enable(1) initialization of bit
- start.asm(32): error: too many characters in character constant
__CSTART_PR     SECTION CODE WORD PUBLIC 'CPROGRAM'
- start.asm(38): error: "#" not expected here
- start.asm(40): error: "#" not expected here
- start.asm(41): error: "#" not expected here
MOV     VECSEG, #(0xC00000>>16)                   //; Set vector table segment
ATOMIC  #3
(this one is OK? Why?)
MOV     SP,     #SOF ?SYSSTACK_TOP              //; Set stack pointer.
MOV     STKOV,  #SOF ?SYSSTACK_BOTTOM + 6*2     //; Set stack overflow pointer.
- start.asm(69): error: unrecognized token
@_CALL(__C_INIT, R1)                    //; initialization of global/static data
- start.asm(93): error: too many characters in character constant
C166_US SECTION LDAT WORD GLBUSRSTACK 'CUSTACK'
start.asm
////;; C166/ST10 startup code generated by EDE for project singlemotor_foc_64mhz
////;; If modifications are needed, disable generation of the startup code in EDE:
////;; In the EDE Project Options dialog select Application, and then Startup. Make
////;; sure the checkbox 'Generate system startup code and add it to project' is not
////;; checked. Note that changes in EDE will now no longer be reflected in the
////;; startup code. Also be aware that the modifications will be overwritten when
////;; the checkbox is enabled again.
$EXTEND2
$CASE
$GENONLY
$NOLOCALS
$CHECKCPU16
$CHECKBUS18
$NOMOD166                               ////; disable the internal set of SFRs
$STDNAMES(regxe164f.def)                //; define SFRs
@SET( BIT_INIT, 0 )                     ////; disable(0)/enable(1) initialization of bit
                                        //; variables at startup
$INCLUDE(head.asm)                      //; Generic definitions (see product include dir)
$INCLUDE(_c_init.asm)                   //; Initialize C variables
        NAME    CSTART                  //; module name
        PUBLIC  __IDLE                  //; cstart end
        PUBLIC  __EXIT                  //; address to jump to on 'exit()'
        EXTERN  _main:FAR               //; start label user program
        EXTERN __C_INIT:FAR
__CSTART        PROC TASK __CSTART_TASK INTNO __CSTART_INUM = 0
        DISWDT                                          //;  Disable watchdog timer
        ATOMIC  #3
        MOV     STKUN,  #SOF ?SYSSTACK_TOP              //; Set stack underflow pointer.
        MOV     CP,     #CSTART_RBANK   //; Set context pointer.
        NOP
        MOV     DPP0, #PAG ?BASE_DPP0   //; Set data page pointer.
        MOV     DPP1, #PAG ?BASE_DPP1   //; Initialise these before we can make a
        MOV     DPP2, #PAG ?BASE_DPP2   //; user stack call below
        //; Set user stack pointer
        //; To avoid problems when the userstack is located at the end of a page, the
        //; initial value is set using base + size.
        MOV     R0, #?USRSTACK_BOTTOM + (?USRSTACK_TOP - ?USRSTACK_BOTTOM)
        BFLDH   PSW, #3, #2             //; set local register bank 0 (10)
        MOV     R0, #?USRSTACK0_BOTTOM + (?USRSTACK0_TOP - ?USRSTACK0_BOTTOM)
        BFLDH   PSW, #3, #3             //; set local register bank 1 (11)
        MOV     R0, #?USRSTACK1_BOTTOM + (?USRSTACK1_TOP - ?USRSTACK1_BOTTOM)
        BFLDH   PSW, #3, #0             //; set to global user stack
        EINIT                           //; End of initialization
        BSET    IEN                     //; allow monitor to break application
        MOV     R12, #0                 //; set argc to 0
        MOV     R13, #0                 //; set argv[] to 0
        MOV     R14, #0                 //;
@_CALL( _main, R1)
//; The exit() function causes normal program termination to occur. First, all
//; functions registered by the atexit() function are called in the reverse
//; order. Next, all open streams with unwritten buffered data are flushed, all
//; open streams are closed and all files created by the tmpfile() function are
//; removed. The status value passed to exit is returned in R4.
__EXIT: LABEL FAR                       //; the exit() or abort() function jumps
                                        //; to this entry.
__IDLE: IDLE                            //; Power down CPU until peripheral inter-
                                        //; rupt or external interrupt occurs.
        JMPR    CC_UC, __IDLE           //; set idle mode again.
        RETV                            //; Virtual return.
__CSTART        ENDP
__CSTART_PR     ENDS
        DS      2                       //; Allocate a user stack of at least 2 bytes
C166_US ENDS
//; Define empty user stack used with localregister bank 0.
C166_US0 SECTION LDAT WORD GLBUSRSTACK 'CUSTACK'
C166_US0 ENDS
C166_US1 SECTION LDAT WORD GLBUSRSTACK 'CUSTACK'
C166_US1 ENDS
C166_US2 SECTION LDAT WORD GLBUSRSTACK 'CUSTACK'
C166_US2 ENDS
C166_SYSSTACK SECTION HDAT WORD SYSSTACK
        DS 512 * 2      //; Reserve stack size in words
C166_SYSSTACK ENDS
        SSKDEF 7                        //; System stack size
CSTART_RBANK REGDEF R0-R15              //; Register usage
        END
