Output uv4 build messages to stdout
I'm building my project via the command line using something like this:
"C:\Program Files\Keil\UV4\Uv4.exe" -b ".\myProj.uvproj"
The problem is that this command does not send anything to the stdout. The only option I see is to output the results to a file, using the -o option. Is there any way of just showing the results in the same command prompt window without resorting to some ugly hack?
Also, is there any way to perform a clean on a project via the command line?
  • I ran into this when integrating my project with Eclipse. I have a batch file called "build.cmd" with the following contents:
    c:\keil\uv4\uv4.exe -b RSN_BB0.uvproj -o errors.txt
    type errors.txt
    Not sure if it's doable without an intermediate file, I tried various tricks with stdout to no avail.
    type errors.txt
