Serial communication
Hi, I tried communication between two uC. Steps are
1) uC1 sends a request (1 byte) to uC2.
2) On receiving this byte, uC2 sends three bytes of data to uC1.
3) uC1 waits for completion of the data reception and stores the data in an array.
All the three steps works ( I am able to display the received bytes correctly using LEDs)
But the problem is I need to add about 1sec delay before every time request is sent from uC1.
(I set a flag to low before sending the request, this flag (global bit) is set to one by the UART ISR when 3 bytes are received. After sending the request, the main program waits for this bit to become high, and then proceeds.Without the additional delay, this bit does not seem to change.)
Is there anything wrong in my method? Why this delay becomes necessary?
