Asm programming
Hello
Where can I find some example programs only in asm to be compiled inder Keil MDK?
I can't compile simple programs as:
STACK_TOP   EQU   0x20002000         ; constant for SP starting value
            AREA  |Header Code|, CODE
            DCD    STACK_TOP  ; Stack top
            DCD    Start      ; Reset vector
            ENTRY             ; Indicate program execution start here
Start       ; Start of main program
            ; initialize registers
            MOV   r0,  #10    ; Starting loop counter value
            MOV   r1,  #0     ; starting result
            ; Calculated 10+9+8+...+1
loop
            ADD   r1,  r0     ; R1R1 + R0
            SUBS  r0,  #1     ; Decrement R0, update fl ag (“S†sufï¬ x)
            BNE   loop        ; If result not zero jump to loop
            ; Result is now in R1
deadloop
            B     deadloop    ; Inï¬ nite loop
            END               ; End of ï¬ le
Keil gives an error:
Error: L6320W: Ignoring --entry command. Cannot find argument 'Reset_Handler'.
How to change this program? How to change linker control string?
I tried also to add startup code fo nxp1766 but then i still have an error that label __main is missing.
Could You help me and give me some simple programs just to compile it properly?
