Hi everyone,
I know this is probably NXP related question, but I suppose there are many skilled guys knowing answer...
I would need to support SDHC cards on LPC2368. There is SD/MMC peripheral available. I didn't know it suppoorts also SDHC. After some research I understood the SDHC means only some more commands (comparing to SD) and thus it is only firmware related thing, so the NXP's hardware peripheral should support both types.
Is this correct assumption? Would SDHC work when I implement SD 2.0 commands?
Thanks for opinions
Regards
Pavel Faltynek
you are correct. however, Keil's FlashFS does not support SDHC at this time.
MMR MICHELE,
Any specific reason for choosing the FlashFS port? You can do that easily with a USB adaptor with firmware modification. follow the link for more info and details.
http://www. .com
