EEPROM code/Patch
Hi all,
I have written a patch mechanism which gives the chance to put a new functionality or fix bugs for ROM code.
i am using the kiel microvision 3 v 8.xx and i wrote a small test (2-3 lines of code, 0x20 bytes) patch routine in a seprate c file and compiled it with the source code (located it in EEPROM area by defining user class "ECODE_MytestPatch(....)") and saved/extracted the hex just for the patch code of EEPROM. I loaded that patch on EEPROM with the old ROM hex file (genrated by compiling without test patch code). It was just working fine.
But when i tried a comparatively bigger size of patch(0x40 bytes or around 6 lines of code and 0x10000 byte or 150 lines of code), it gives unexpected behavior i tried to analyze the problem and found following things
1) xdata was increased (I used far keyword and it was shifted to HDATA)
2) CODE segment size was increased (I think this is the problem as in smaller patch code this value dint increase).
3)ECODE_MyTestPatch segment increased (this is the patch code located to EEPROM)
4) some ?L?COMxxx segments appeared in CODE segment.(I think these are genrated because i am using some ROM functions in my patch code but i am not confirmed).
I thought there might be some process/mechanism through which i can only genrate the hex file from patch code without getting touched/changed the ROM hex i.e. only generate the eeprom hex file not regenrate entire ROM hex again.But i cudnot find that.
I have no clue why the code size is increasing. I have no clue how to solve this problem.
Could anybody be so kind to help me on this issue?
Regards
Ankit
  • Do I understand this correctly - you really are trying to patch a binary image? That would be too troublesome with the standard tools, as you are beginning to discover. The standard approach is to have a bootloader and to update the whole firmware when necessary.
    But binary patching is not impossible. For example, there is a company (Ksplice) that provides the service of patching a running linux kernel. But it's not easy, you have to jump through many hoops. You'll only want to do it when you _really_ have to.
