Ensure thread safety in ARM C/C++ libraries
Dear forum,
right now I am struggling with enabling thread safety for my ARM C/C++ libraries.
Here's the problem I am facing:
Actually I am running a multithreaded application on my Cortex-M3 device.
I am facing spontaneous crashes and suspect the source of these crashes rooted inside the C or C++ library.
As a solution I am trying to make the libraries thread safe as described here:
[1]
http://www.keil.com/support/man/docs/armlib/armlib_Chdcgdbh.htm
and here:
[2]
http://www.keil.com/support/man/docs/armlib/armlib_Chdfjddj.htm
Actually I tried to implement [2] by writing
extern "C" int _mutex_initialize(int* p_pMutex)
{ return 1;
inside my main.cpp file.
The problem is that _mutex_initialize is never called. Is there a special switch or anything that I have turn to force the C library calling my _mutex_initialize function?
Many thanks in advance and best regards
Jan
  • I have obtained solution for this issue from Keil support:
    *** 2011-05-19 10:09 BST *** Barth, Andreas/ARM:1187425 andreas.barth@arm.com ***
    Dear Jaroslav,
    here my explanation of the problem.
    No, I think this does not depend on the amount of compiled code.
    You can activate this effect also in my example by using the C/C++ option "One ELF section per
    function" (which you have also enabled in your project).
    Then the following manual entry is also relevant:
    infocenter.arm.com/.../index.jsp
    The functions _mutex_acquire and _mutex_release are only weakly referenced by the library. As
    there is no other object in the the ELF sections with this function, they will not pulled in by
    the linker. This explains the manual entry.
    So to solve the problem, don't use "One ELF section per function" or better, use the
    __attribute__((used)) on that 2 functions.
    __attribute__((used)) void _mutex_release (void* mutex)
    __attribute__((used)) void _mutex_acquire(void* mutex)
    Opposite to this, function _mutex_initialize is strongly referenced by the library and will not
    have this problem.
    I hope this information explains the situation.
    Best regards,
    Andreas Barth
Reply Children
