Battery RAM
Controller : LPC2368(ARM 7)
Issue : Battery RAM values not storing . Junk values getting stored on it.
Hi People ,
I am using LPC2368 (ARM7) . I am facing the following issue with the
Battery backup RAM .
My Pclk for Battery backup RAM is Pclk = Cclk / 4 ;
And I am storing data as shown below
#define BATTERY_RAM_BASE_ADDRESS 0xE0084000
/* ALLOCATION */
#define BSR_Data1 (*(volatile unsigned
long*)(BATTERY_RAM_BASE_ADDRESS 0x000))
#define BSR_Data2 (*(volatile unsigned long
*)(BATTERY_RAM_BASE_ADDRESS + 0x004))
#define BSR_Data3 (*(volatile unsigned long
*)(BATTERY_RAM_BASE_ADDRESS + 0x008))
As Static Battery RAM can be accessed only word-wise(32bit only)
Note : The Battery RAM is a 2 kbyte static RAM residing on the APB bus.
The address range is
0xE008 4000 to 0xE008 47FF. The SRAM can be accessed word-wise (32-bit)
only.
And I store it as ,
Unsigned int Store_Data;
Store_Data = BSR_Data1 ;
And Reading it as
BSR_Data1 = Store_Data ;
Is this the Correct way ?
Because after a day all the data that I store is getting erased.
Thanks in advance, Pls help me out guys on this issue.
Regards,
Samjith Wasim . A
