I'm working with MDK_ARM V4.00
I would like to use os_evt_get to identify the current event in a task and I've obtained a strange result !
My source is :
EvtFlag_T1 = os_evt_get() ;
result = os_evt_wait_or (0x0040 | 0x4000, 20); if ( OS_R_TMO == result ) { ErrTimeout++ ; } else { NoErrTimeout++ ; }
/* Wait now for 50 ms */ os_dly_wait (5);
With this source I'm obtaining the follwing results First call at os_evt_get() function EvtFlag_T1 is set to 0 I'm waiting events 0x0040 and 0x4000. Thess events are not post by my application so os_evt_wait returned to me a timeout error Second call at os_evt_get(), EvtFlag_T1 is set to 0x4040
Strange, I'm obtaining the event I'm Waiting not the current event of a task. Bug ? or not. Could you help me? thank.
I try the same example with MDK-ARM 322 and MDK-ARM 4.02. I obtained the same result
regards
The os_evt_get() is valid only for OS_R_EVT return value from os_evt_wait_or(). On timeout, the value of os_evt_get() is undefined.
Thanks you for all
