Dear all:
Hope you will be doing Great.
I am on Project to integrate ARM series Microcontroller to sense colors i.e. Red, Green & Yellow colors.
Can anyone of you suggest me IC for Color sensing.
Thanks & TakeCare!
Hi try the following links: www.majantys.com/.../f5eab476dcd4a03d4bc88c011c9be079.pdf http://www.mazet.de Good luck
... or do those links look a bit suspicious?
especially the name of that "pdf" file...
Am i just paranoid... Andrew Neil ... or do those links look a bit suspicious?
I wouldn't open them either but then, maybe I'm paranoid as well. Anyhow, at a former place of work, the IT guy was amazed, his records showed that I was "very web active" and I had the least infected computer in the company.
PARANOIA IS GOOD!!!, that is a sad fact that a few bad apples have forced the good ones to accept.
