uV debugging of externally compiled files
I'm starting to work with the Keil MDK_ARM_4.14 and I have some problems with setting up a project for debugging. I build my software with an external build process using a makefile. The output format is dwarf2 and the file extension of the debug file is *.elf.
My first problem is to change the file extension of the debug file in the uVision environment. uV always requires a *.axf file. Is it possible to change this standard extension? My current workaround is to rename my elf-file to *.axf.
My second problem is the debugging behaviour of the uVision environment. When I compile a project completely in uV then the debugger automatically opens a source file when a function call is executed outside of the current file. When I use my externally build debug file the debugger doesn't do this. That means if a function call is executed, I need to open the file manually and then the executed position is shown properly after the first single step command. Does anybody know the reason for this behaviour?
I hope anyone can help me.
Cheers,
Ralf
