I am using LPC1768 and programming it using ISP. What i have observed is that the programs that i load work fine but when i repower the LPC board, the code starts to work only after a reset.
The code executions should start after powerup.
Kindly let me know what could be the possible issue.
Something wrong with your reset circuit?
Thanks for your response
It would be great if you check this circuit from below link
The reset and isp circuit i have uploaded to this link The RST# goes to controller pin 17.
www.flickr.com/.../53850468@N08/4972977957/
