Kernel Objects - Pipes
Does the concept of a Pipe kernel object exist in RL-RTX? This is typically found in VxWorks for instance.
#define SU_PIPE_CHECK(p)
#define SU_PIPE_CREATE(p, w, l, name)
#define SU_PIPE_DELETE(p)
#define SU_PIPE_GET_INF(p, dp)
#define SU_PIPE_GET_TMO(p, dp, tmo)
#define SU_PIPE_PUT(p, dp)
If it does not exist could it be implemented using some other construct available in RL-RTX?
