When I am trying to compile my code, i am getting the following error ERROR L115: PARTIAL SEGMENT BELONGS TO DIFFERENT MEMORY CLASS SEGMENT: ?C_C51STARTUP MODULE: C:\KEIL\C51\LIB\CH51L.LIB (?C_INIT) can any body explain me why this error and how it can be resolved?
The first thing to note is that it's not a Compiler error; it's a Linker error - so you need to look it up in the Linker Manual.
Unfortunately, the text of your L115 message doesn't match the description in the online documentation: http://www.keil.com/support/man/docs/lx51/lx51_l115.htm http://www.keil.com/support/man/docs/bl51/bl51_l115.htm
SO you're going to have to check the documentation that's included in your Keil installation.
If you click the message in the uVision output window, then press F1, it should take you to the description....
"the text of your L115 message doesn't match the description in the online documentation"
You appear to have specified the wrong toolset - that looks more like the L115 message from the L251 Linker:
http://www.keil.com/support/man/docs/l251/l251_l115.htm
Or maybe LARM:
http://www.keil.com/support/man/docs/la/la_l115.htm
