Hello, my problem is a simple one, the soloution may or may not be.
Basically to convert the resistance of a thermistor directly into a temprature the following equation is used.
T =1/ [A + B*Ln(Rt) + c*(Ln(Rt)^3))]
T is temp in kelvin Rt is thermistor resistance
For my 100k thermister A = 0.001279138 B = 0.000146393 C = 2.55E-7
When i read my ADC values into excel and do all the calculations i get a very accurate temprature reading to within about .2 deg
When i do all the math internal in the micro there is (at room temp anyway) 1 deg of error. nearest i can see it is bacause the log() function is truncating the decimal places it puts out. I need 9 places after the decimal and i only get 5.
Is there any workaround for this or an option in the math header that needs to be set, maybe a better log() function?
Thanks, Tom
You could use a lookup table with a sufficient number of points and a suitable interpolation function instead of burdening the 8051 with floating-point calculations.
That is what I usually do.
The error was actually just a stupid mistake in my "on PC" calculations. The uPs math is fine.
I had used a value of 2.4V for my ADC calculations in VB and excel, 2.44 on the uP.
Thanks for the help.
