There is example:
#include <LPC288x.h> int main(void){ PINS_3 = 0x03; return 0x00; }
and file .ini
$=0x10400000
In debug Simulator line PINS_3 = 0x03; causes(calls) interruption PAbt_Handler.
Why if PINS is defined in LPC288x.h as #define PINS_3 (*((volatile unsigned int *) 0x800030C0))?
That to adjust in IDE for correct simulator?
Project is created in MDK-ARM, adjustment by default. Keil MDK-ARM v3.80a
Ask Keil support.
Support simulated this chip will be in future version?
This chip is not simulated.
http://www.keil.com/dd/chip/4186.htm
