MCI driver for microSD with SPI access
I need to replace the MCI driver of the Keil Example Code
\Keil\ARM\Boards\Keil\MCB2300\RL\USB_FlashFS\SD_File
by a driver which accesses the microSD card via the SPI interface in SPI mode instead in native mode, since I am using a target device without MCI peripheral block (LPC214x).
Is there an example available which provides USB Mass Storage access to a microSD card connected via SPI in SPI mode together with FlashFS access as shown in the above Example Code?
Thank you very much in advance,
Oliver
