Hi , I'm newbee to ARM controller family.I'm trying to Receive a Message from GPS(Global Positioning System) and Sending to an GSM modem.
I'M using LPC2148 controller. My freq for controller is 12MHz. I need Help on how to intialize both the UARTs.
My code for Intilization is written as fallows,
void SerialInit1 (void) // this intialization for transmitting a msg to GSM modem { PINSEL0 = 0x00050000; // Enable RxD1 and TxD1 (for UART1) U1LCR = 0x00000083; // 8 bits, no Parity, 1 Stop bit U1DLL = 0x000000C2; // 9600 Baud Rate @ 30MHz VPB Clock U1LCR = 0x00000003; // DLAB = 0 } void SerialInit0 (void) // this intialization for receiving msg from GPS { PINSEL0 = 0x00000005; // Enable RxD1 and TxD1 (for UART1) U0LCR = 0x00000083; // 8 bits, no Parity, 1 Stop bit U0DLL = 0x000000C2; // 9600 Baud Rate @ 30MHz VPB Clock U0LCR = 0x00000003; // DLAB = 0 }
I doubt this is not the the proper way of intializing the Both UARTs..Can someone throw light on it?
Thank you Regards, Kush
