I'm writing a code that wil receive and send a string through serial port (UART). The setup of the ARM is good. Now, I would like to know if is there a command, function, code, and so one that I can write the message as the way we speak and the program converts it to decimal ASCII and the opposite too.
example:
send 'ARM microprocessor'
I was told that Keil have a key for this but I didn't find it.
I'm using MCB2300 with LPC2368.
Thanks a lot.
Edson
A more typical beginner's first example would be to send, "Hello, world"
http://www.keil.com/support/man/docs/uv4/uv4_ex_hello.htm
http://www.keil.com/support/man/docs/gsac/
