Hy
I would like to debug processor Cotex M1 on board (ACTEL advanced development kit) with ULINK2 debugger. I would like debug from external SRAM. When I started the Debug Session, I gave an error message Invalid ROM Table. JTAG communication is OK, because I find the device name ARM CoreSight JTAG-DP in window Cortex-M Target Driver Setup - JTAG Device Chain.
I also tried debug from on-chip Flash and on-chip RAM, but I gave a similar error message.
I don't find any useful material about connection between CotexM1 and ULINK, therefor my connection between them is wrong too.
I debuged CortexM3 by KEIL ULINK2,too. I don't have any problem. I use tutorial:
www.actel.com/.../SmartFusion_Libero_Keil_POTlevel_tut_UG.pdf
, but for CortexM1 I don't find any tutorial.
i have the same problem with a Cortex M3. But could progamm the cortex a few times. Have you found an solution?
