cannot connect HDD to EZ-USB FX2LP
I have a development borad EZ-USB FX2LP.
I installed the software development kit and tried the example.
I compiled the FX2_ATA example code with Keil-SW ( without changing anything in source).
I connected a CF CARD with adapter to the IDE port, downloaded the FX_ATA.iic file onto EEPROM.
The system renumerates and I could access the CF card.
Now I exchanged the CF adapter for a normal 160GB PATA HDD.
After reconnecting the board to the PC the HHD permantenly "reset"'s,
no renumeration, so I could not access the HDD.
The HDD is OK on a different(standard) USB2IDE connector.
I modified the maximum packet size in the desr.a51 file from 64 to 512 byte, but without succes, I still cannot acces the HDD. (I don't know if this is OK)
Now I have no idea what could be different, between accessing a CF card to a HDD with this board?
Can someone give me some hints?
Is there a difference in source code for FX and FX2LP?
